Прием и обсуждение 43.2°W - Intelsat 32e Ku диапазоне
Ресивер: TBS 6983, TBS6522
Антенна(ы): 2,20m, 3,70m
Благодарил (а): 487 раз
Scan V and H
regards dreamsat
satesco
Ресивер: DM920 UHD,Vantage HD 7100 S
Антенна(ы): 150cm
Благодарил (а): 359 раз
Only two transponders I'm picking up from this position:11855 V and 11891 V,both with stream generic.
Hi satesco,
here is my Scan
regards dreamsat
satesco
Антенна(ы): 150cm
Hi dreamsat,
Congratulations :-) As usually,excellent result.I look at the dB value obtained on every transponder you received,and I can only say that I dream when I look at your results.With my antenna I have over 12 dB with a 1.50 m dish,and you get over 20 dB with your 2.20m antenna(or 3.70m?). Paraphrasing, I'd say:"Tell me what dish you have,and I'll tell you your ambitions."In your case,the results are in line with this ambition :good:
Best regards :-)
it is with 3,70m Satellit Dish scanned :good:
regards dreamsat
satesco
Антенна(ы): 150cm
dreamsat писал(а): 16 фев 2018, 20:11 it is with 3,70m Satellit Dish scanned :good:
regards dreamsat
Please check 11856 V with your dish.On my spectrum the signal disappeared,instead 11664 V,7165,3/4,8PSK was activated:
@ satesco
There is nothing
regards dreamsat
