Peon
Благодарил (а): 383 раза
Hello friends,
How to determine the exact length of the waveguide ?? The length should always give a multiple of the wavelength (26mm).
I would measure from the waveguide at the feed horn beginning to behind the taps H and V. I flan all LNBs myself and the screwed waveguide with feedhorn always have different lengths. I wanted to optimize this.
Best regargds dreamsat[/quote]
Hi dreamsat :drinks:
The ideal waveguide would be a variable length waveguide. But that is the problem to realize. The differences between the ideal and the average length is minimal. Therefore, it is best to use the length calculated for the center of the received frequency band. :-)
Peon
Peon писал(а):
06 фев 2018, 09:33
Peon
Hello. I think waveguide length must be in closely relationship with length of Ku-band wave.
Peon писал(а):
06 фев 2018, 09:33
Peon
Тут я с вами не согласен. Длина волновода должна быть рассчитана относительно средней длины волны диапазона. Она не равна длине волны средней частоты диапазона.
Об этом я писал здесь: ТЕМА ПРО ВОЛНОВОДЫ
Там же есть смысл вести дальнейшую дискуссию.
Длина волновода (от облучателя до задней стенки) должна быть равна
L = NхLambdaaver/2 + Lambdaaver/4
Peon
06 фев 2018, 11:05
Peon писал(а):
06 фев 2018, 09:33
Peon
приветствую strannik :drinks:
Я написал то же самое. Переводчики Google, вероятно, не переводили их правильно. :-D
Peon
Благодарил (а): 494 раза
Hello friends,
thanks for the helpful contributions. I'm talking about the length of the LNB waveguide. The feed raw has a calculated and thus defined length. But the LNB are different in length. Would it be better now to turn off all LNb to a length ?? The short single LNB have their own length again and one is not very variable there because so short.
What do you all mean.
best regards dreamsat :drinks: :friends:
Peon
dreamsat писал(а):
06 фев 2018, 20:46
Hello friends,
LNB manufacturers save where they can. :roll:
Therefore, do not expect quality on cheap products. :crazy:
Peon
Peon писал(а):
07 фев 2018, 08:52
Peon
I think better need to ask strannik in this thread http://sat-dx.club/viewtopic.php?p=23871#p23871
Because i need this information too, for creating cone for ADE antenna.
Нужна небольшая помощь в анализе выбора антенны.
Нашел антенну российского производства диметром 5.1метра
Как вы думаете, даст ли она лучшие результаты, чем ADE 4.5метра?
Уважаемы strannik, как вы считаете, если на нее установить inverto balck ultra с конусом, покажет ли она лучшие результаты чем NWIEE ADE 4.5m?
Спасибо.
zman, интересный вы человек - задаёте вопросы, а никаких исходных данных для ответа или совета по существу не даёте...
Вам нужен переходник к волноводу - "помогите сделать конусный переход", а какие размеры волновода, какой LNB вы собираетесь подключать и каковы размеры его входного волновода (или фланца) - вы не сообщаете :-(
Спрашиваете про сравнение антенн - и снова не ясно, чем вы облучаете ADE 4.5метра и каков угловой раскрыв антенны 5.1м
По площади антенн можно только сказать, что при оптимальном облучении обеих усиление антенны 5.1м в 1.28 раза больше (или на 1.09дБ)
11 фев 2018, 13:56
Облучал ADE антенну вот так viewtopic.php?p=23726#p23726
Я прочитал в соседней теме, что для ку диапазона эффективность ADE антенны не более 60% http://sat-dx.club/viewtopic.php?p=16821#p16821
По этому решил провести поиски другой антенны, попалась российская с установкой lnb перед зеркалом.
Думаю, что в данном случае, если изготовить конус для lnb и установить вместо текущего Си коневертора,
то будет коэффициент усиления большем чем, если основываться на разнице диаметров антенн.
По этому и спрашиваю Вашего совета, т.к. меня смущает ее российское происхождение (так как мне неизвестно, какой эффективности делают россияне антенны, по сравнению с андрю или джонса)
(сейчас другой конус перехода для ADE делать не планирую, думаю что лучше сразу 5метровой антенной заняться)
